It is currently Mon Jul 28, 2025 5:12 pm
PostPosted: Sun Jun 14, 2020 8:43 pm
Do you always install truss rods on your instruments?
I understand the potential need for one, but so you guys do them on all guitars?
What makes me pause is I’m building up a 20s L1 style. Shorter scar modern gib 12 fret.
I’m not building an “replica” but I dig the shape:) the bracing and other aspects will be different.
This is a small guitar.
So, even on little guys, older style, do you always do a TR? Maybe a CF reinforcement instead?
I suppose the potential need for one out weighs the novelty of a lighter feel
PostPosted: Sun Jun 14, 2020 10:44 pm
Yes.
Not every player, not every string set, not every set up requires the same relief. To have that be adjustable is imperative IMO. We have the technology. 2 way rods are where it’s at.
These users thanked the author meddlingfool for the post: SnowManSnow (Tue Jun 16, 2020 2:06 pm)
PostPosted: Mon Jun 15, 2020 1:49 am
First name: Josh
For me, yes.
The small investment of time and money to add a 2-way rod pays itself back very quickly when you consider what is required to finesse the relief on a guitar with no rod.
Of course, methods of adjusting relief on guitars with no truss rod exist. But if you have installed a rod all it takes is a few seconds with an allen wrench. This time saving adds up over the service life of a quality instrument, which should be 50+ years for something well built and which will include many set-ups and tweaks as the years roll by.
Yes, there is a weight consideration; this is an ergonomic thing that is a bigger deal for some players than others. There are lightweight options on the market that still allow 2-way adjustment.
These users thanked the author joshnothing for the post: SnowManSnow (Tue Jun 16, 2020 2:06 pm)
PostPosted: Mon Jun 15, 2020 3:50 am
Yes.
These users thanked the author Colin North for the post: SnowManSnow (Tue Jun 16, 2020 2:06 pm)
PostPosted: Mon Jun 15, 2020 5:32 am
First name: Victor
Last Name: Seal
City: Osseo
State: MI - Michigan
Zip/Postal Code: 49266
Steel strings= always. Nylon strings = no.
These users thanked the author Victor Seal for the post: SnowManSnow (Tue Jun 16, 2020 2:06 pm)
PostPosted: Mon Jun 15, 2020 5:41 am
Many of the older non-truss rod guitar necks that were built for steel strings had thick baseball bat like cross sections. Some weight was still there in the additional wood. After the single action rod was invented thinner necks could be safely used and weight gain was probably minimal. Double acting rods have become popular, but in most cases they do add weight to the neck. Now some companies are making double acting rods of lighter materials (at somewhat greater expense).
If you want a lighter neck, my suggestion would be to use a single action rod, pretension the rod to induce - some - "back bow" in the neck, re-level the fingerboard so releasing the tension then allows the neck to bow forward. This will give some of the advantages of the double acting rod without the weight penalty. You don't want to pre-tension the rod so much that it no longer has enough movement to act as it normally should, so it is somewhat of a balancing act.
I make my own single action rods but Stew Mac also sells them.
These users thanked the author Clay S. for the post: SnowManSnow (Tue Jun 16, 2020 2:07 pm)
PostPosted: Mon Jun 15, 2020 6:21 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
meddlingfool wrote:
Yes.
My thoughts exactly. If it is a new build (not a repair of a very old instrument), I just have no reason to leave a truss rod out, and every reason to put it in. Weight savings are not really important enough to me to sacrifice the ability to adjust the neck's relief, and thereby optimize the guitar’s action. As a player, I want the guitar to have what I subjectively feel is the perfect action, which depends on being able to dial in the right relief. I would put up with a guitar being a little heavier if it is otherwise a great guitar, but it can’t be a great guitar unless it has (or can have, with tweaking) the right relief, making ideal action possible.
These users thanked the author doncaparker for the post: SnowManSnow (Tue Jun 16, 2020 2:08 pm)
PostPosted: Mon Jun 15, 2020 6:57 am
Last Name: Parker
City: Charleston
A bit more: don’t confuse stiffness with adjustability. A truss rod gives the neck adjustability more than it gives the neck stiffness. Adjustability is more of what you need from a truss rod, in my opinion. You can have a straight and very stiff neck, relatively unaffected by string tension, and the relief (and therefore the action) might not be ideal. Without a truss rod, getting to ideal would be a lot of work.
PostPosted: Mon Jun 15, 2020 8:17 am
Having worked on many over the years I definitely prefer a 2 way rod over a single compression rod. Being able to adjust either direction is a huge advantage.
That being said. Lots of guitars have been made with compression style rods and do just fine. But given that we have the technology now the 2 way is king in my opinion.
These users thanked the author DanKirkland for the post: SnowManSnow (Tue Jun 16, 2020 2:08 pm)
PostPosted: Mon Jun 15, 2020 8:48 am
Steel strings yes, always.
Do a few compression frets then you can answer your own question ;)
These users thanked the author SteveSmith for the post: SnowManSnow (Tue Jun 16, 2020 2:08 pm)
PostPosted: Mon Jun 15, 2020 9:22 am
I've built a few with non-adjustable truss rods. I don't use them on Spanish guitars either. But in general I use TR's and I like the double action ones.
These users thanked the author jfmckenna for the post: SnowManSnow (Tue Jun 16, 2020 2:08 pm)
PostPosted: Mon Jun 15, 2020 10:29 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Yes double action always on SS sometimes on nylon.
These users thanked the author johnparchem for the post: SnowManSnow (Tue Jun 16, 2020 2:08 pm)
PostPosted: Mon Jun 15, 2020 1:30 pm
Last Name: Kincheloe
My steel string harp ukulele (15" scale, 12 fret walnut neck with 4 strings on it about 15lbs each) has no reinforcement, and playability remains excellent after being exposed to the extreme seasonal humidity swings here for 5 years.
But for anything over 20" scale I'd include a rod for adjustability. For absolute lightest weight, use Spanish cedar with an Allied ultralight rod. Second lightest and about $25-30 cheaper is a cherry or walnut neck with steel compression rod. Stainless would be better for corrosion resistance, but I haven't had any trouble with mild steel from the local hardware store.
These users thanked the author DennisK for the post: SnowManSnow (Tue Jun 16, 2020 2:09 pm)
PostPosted: Tue Jun 16, 2020 2:23 pm
The allied rods are interesting. I’m not completely certain how they are installed and such but cool
Users browsing this forum: Mike Thomas and 17 guests
